The Better to See You With
Scientists build record-setting metamaterial flat lens
NIST
Wed, 05/29/2013 - 12:07
For the first time, scientists working at the National Institute of Standards and Technology (NIST) have demonstrated a new type of lens that bends and focuses ultraviolet (UV) light in such an unusual way that it can create ghostly, 3D images of objects that float in free space.
The easy-to-build lens could lead to improved photolithography, nanoscale manipulation and manufacturing, and even high-resolution 3D imaging, as well as a number of as-yet-unimagined applications in a diverse range of fields.
“Conventional lenses only capture two dimensions of a three-dimensional object,” says one of the paper's co-authors, NIST's Ting Xu. “Our flat lens is able to project three-dimensional images of three-dimensional objects that correspond one-to-one with the imaged object."
