Unique three-dimensional solar cells that capture nearly all of the light that strikes them could boost the efficiency of photovoltaic systems while reducing their size, weight, and mechanical complexity. The new 3-D solar cells capture photons from sunlight using an array of miniature “tower” structures that resemble high-rise buildings in a city street grid. The cells could find near-term applications for powering spacecraft, and by enabling efficiency improvements in photovoltaic coating materials, could also change the way solar cells are designed for a broad range of applications. “Our goal is to harvest every last photon that is available to our cells,” says Jud Ready, a senior research engineer in the Electro-Optical Systems Laboratory at the Georgia Tech Research Institute. “By capturing more of the light in our 3-D structures, we can use much smaller photovoltaic arrays. On a satellite or other spacecraft, that would mean less weight and less space taken up with the PV system.”
Jud Ready, senior research engineer at the Georgia Tech Research Institute, holds a sample of the 3D solar cells his research team has developed. |
