Common Misconceptions About 3-D Scanning
Separating fact from fiction
Laser Design Inc.
Mon, 05/16/2011 - 05:30
Fact or fiction? Data acquired with 3-D scanning is inferior to that acquired via a touch probe and a coordinate measuring machine (CMM). This most certainly is fiction. The fact is that 3-D scanning captures tens of thousands of points per second, an enormous amount of data that makes the process statistically superior.
What other misconceptions about 3-D scanning have you heard (and maybe believed)? Read on to separate the fact from the fiction.
Fiction: The size of objects you can scan is limited.
Fact: Practically speaking, there are no upper or lower boundaries on the size of objects that can be scanned. You can scan parts smaller than a ball point on a pen and larger than a football field. Long-range scanning (terrestrial laser scanning) enables 3-D capture of virtually infinite-sized objects and areas because the size of the specimen being scanned is no longer limited to the directional travel of a machine or the reach of a measuring arm.
