(Newport Corp: Irvine, CA) -- Newport Corp., an industry leader in optical power measurement, has introduced the Series 819C/D high-power, silicon-based integrating sphere detectors that operate in the ultraviolet (UV down to 200 nm) and can handle up to 10 watts of optical power. The new CAL2 models feature a built-in temperature sensor and OD1 attenuator sensor. When connected to Newport’s power meter models 1830-R, 1918-R, 1936-R, or 2936-R, they automatically recognize the attenuator on/off position and the detector head temperature.
Calibrated and traceable to NIST standards, the 819C/D Series spheres operate in wavelengths ranging from the UV region through the visible to the near-infrared (NIR) at 1650 nm. The detectors offer superior and accurate measurements with the market’s smallest calibration uncertainty specifications. Available for both diverging (model 819C) and collimated (model 819D) input beams, the line extension to UV and higher-power features make this series an essential tool for critical optical power measurement applications.
