(Advanced Test Equipment Corp.: San Diego, CA) -- The state-of-the-art mass spectrometer leak detector and vacuum system by Varian provides powerful capability, enabling a broad range of test methods for specific applications, including industrial process, power generation, high energy physics, semiconductor production, small parts manufacturing, and general research and development.
Superior pumping characteristics such as high inlet pressure tolerance and split flow capability deliver fast response and clean-up times, thereby maximizing production throughput. High test-port pressure allows for detection of large leaks, while a 12-range MDL (sensitivity) meets the most stringent leak test requirements. Wireless remote control with an operating range of 100 meters (328 feet) enables single-person leak testing of even the largest systems.
With simple and intuitive two-button operation, the VSMR15 allows for intermittent use without excessive training requirements. Not only is this unit easy to use but the mobility of the two-wheel cart option makes the leak detection process simple to carry out and easy to transport from one application to another.
