REIS’ RH Series Robots Improve Extraction at Die-Casting Machines
For removing, inserting, and spraying in the casting foundry
Reis Robotics
Wed, 11/02/2011 - 15:47
(REIS: Obernburg, Bavaria) -- REIS Robotics, a leader in system integration of robots, has completely revised its RH robot series and greatly improved its use for removal, insertion, and spray robots in the casting foundry.
The series comprises two robot types with six axes up to a load capacity of 130 kg, as well as two robot types with four basic axes for load capacities up to 300 kg. The basic units with four axes can be equipped with an additional fifth casting axis and are mainly used as casting robots for gravity die casting.
The six-axes, articulated arm robots of the RH series are particularly outstanding due to a high load capacity and a high positioning accuracy at high speeds. Due to the horizontal arrangement of the arm, results are of an ideal movement sequence for extraction, insertion, and spray tasks at the die-casting machine.
