(Marposs Corp: Auburn Hills, MI) -- Marposs will be introducing the Artis CTM V6, a tool, machine, and process monitoring system, at Amerimold 2014, the conference and exhibition for mold manufacturing, running June 11–12, in Novi, Michigan.
The CTM system safeguards and optimizes complex production processes thanks to aligned in-process monitoring. The flexible interface concept enables problem-free integration within many environments, from entry solutions with no fieldbus connections, to branched Ethernet architectures such as PROFINET, Ethernet/IP, and Modbus.
Using the CTM system, evaluation and control are carried out with process-dependent strategies. Instead of searching for the smallest common denominator, CTM offers a range of strategies to optimally monitor the process. Each individual parameter can be very finely adjusted and precisely adapted to the process. Process monitoring operates precisely and reliably from the very first cut.
