The most significant change in the upcoming revision to ISO 9001 is probably not what you'd expect it to be: It's not customer satisfaction, continual improvement or even the process-model structure of the standard. The most significant change is the requirement for quality objectives. ISO 9001:2000 requires that quality objectives be established at each relevant function and level within the organization (i.e., just about everywhere). The manner in which quality objectives are established and managed will have an enormous impact on the organization's performance. The quality objectives will either drive strategic improvements throughout the organization, significantly elevating the importance of the quality management system, or they'll simply become a meaningless exercise in data collection. It all depends on how the task is carried out.
The basic requirements for quality objectives are quite simple:
