(Sherborne Sensors: Wyckoff, NJ) -- Sherborne Sensors has introduced the T640 series, a range of high-reliability solid state tilt sensors, offering precision measurement accuracy for data acquisition systems, road bed analysis, platform and pipeline leveling, structural monitoring, ship ballast transfer systems, and other applications.
Available in ranges of ±30°, ±60° and ±90°, the Sherborne Sensors T640 series range features an advanced solid-state micro-electromechanical systems (MEMS) sensor, incorporating integral air damping. Unlike fluid-damped devices, air damping is essentially independent of temperature, which enables the tilt sensor to reliably perform over a very wide temperature range (-40°C to 100°C), with essentially zero temperature coefficient of damping ratio. Units are compensated for effects of temperature on both sensitivity and zero, and incorporate positive mechanical stops, conferring excellent shock resistance.
