(Sensors Unlimited Inc.: Princeton, NJ) – Sensors Unlimited Inc. has announced the new SU1024LDH2, a high-speed, digital line scan short wave infrared (SWIR) indium gallium arsenide (InGaAs) camera. The second generation 1,024-pixel, high-speed camera features an increased line rate to more than 91,900 lines per second, making it ideal for spectral-domain optical coherence tomography (SD-OCT) imaging applications. In the 1.05 µm wavelength band, the new imager can capture detailed 3-D SD-OCT volumes of the retina, choroidal vasculature, and nerve head, offering important detail beyond the depth capability of current 0.84 µm systems.
The compact camera housing features metric and SAE mounting holes on multiple sides for easy configuration into existing systems or for other positioning purposes. Small (3 in. W × 3 in. H × 2.4 in. L) and cost-effective, the LDH2 SWIR camera can be easily mounted to spectrometers. Optional adapters are also available for C-mount, F-mount, or FD mount lenses for use with machine vision applications.
Goodrich’s new high-speed camera has a wavelength response range from more than 0.8 µm to 1.7 µm with a 25 µm pixel pitch and aperture heights of 25 µm or 500 µm.
