● (Contact: Kevin , Email: oilpurifier.kevin@zhongnengcq.cn, kevinnchiang@gmail.com , MSN: new8628@hotmail.com , Skype: kevinnchiang , Yahoo Messenger ID: kevinnyll ,Google Talk ID: kevinnchiang@gmail.com , Tel: +86-23-68064015 , Fax: +86-23-68060921, Mobile: +86-13527390908, Alibaba-Talk Trademanager ID: cn200536006, http://bestoilpurifier.bossgoo.com, http://www.zhongnengcq.cn)
● Keywords/Tags:
Oil reclamation system | Oil regeneration system | Oil purification system | Oil filtration system | Oil degassing | Transformer oil purification system | Transformer oil purification | Transformer oil reclamation system | Transformer oil regeneration system | Transformer oil filtering | Transformer oil treatment | Electric supply | Transformer repair and maintenance | Transformer oil re-processing
● Product Description:
As is well known the Transformer plays an important role in the generation, transmission and distribution of electrical energy. Under load the transformer, dissipates heat and the insulating oil acts as a coolant as well as an effective dielectric.
Due to the highly hygroscopic nature of the transformer oil, it absorbs moisture from windings, which leads to gradual deterioration of dielectric strength. Also there are some waste impurities, gas contents in the transformer oil which destroy the oil’s quality.
Zhongneng oil purifier is the most efficient and economical purification system.
● What Does Transformer Oil Regeneration System Do?
This oil purification plant is applied to filter various of unqualified insulation oils including aging transformer oil specially for the power which is above 110KV, mutual inductor oil, switch oil and so on. Also it can inject the insulating oil into the transformers on-line.
● What are the Main Features:
1. Duplex 3D stereo-evaporation, eliminating the liquid water quickly
2. UK G technology by which the trace water that is show chain, such as dissolved water, can be removed effectively.
3. Distinctive removing impurities system filtering through double FH trapezoidal network and absorbing by high polymer without the mechanical power
4. Carbon fiber infrared heating system that can make the oil contains zero sum of ethyne after the treatment
5. Especially applied to vacuum oiling and drying for power transmission equipments which are over 110KV
6. The oil of any grades can be treated on line at the working site.
7. Can be operated both on-load and off-load.
8. Can be operated fully-automatically with PLC controller.
9. Oil purifier can be made in hermetical, canopy-covering, open and frame style.
● What are the Main Advantages, comparing the common oil purifiers:
This machine dewater, degas and removes the impurities more quickly, more completely, and makes the oils limiting voltage-withstand value much higher. As the bridge-type vacuum linking system that can purify and also can be an independent vacuum power supply, this machine can treat the electric insulation devices.
According to fieldwork requirement, this machine equips car wheels, which can be easily moved to any work point by traction. It is especially suitable for purifying transformer oil which locates in fields.
This machine can seriously recover transformer oil. The treated transformer oil can reuse again in transformer.
