● (Contact: Kevin , Email: oilpurifier.kevin@zhongnengcq.cn, kevinnchiang@gmail.com , MSN: new8628@hotmail.com , Skype: kevinnchiang , Yahoo Messenger ID: kevinnyll ,Google Talk ID: kevinnchiang@gmail.com , Tel: +86-23-68064015 , Fax: +86-23-68060921, Mobile: +86-13527390908, Alibaba-Talk Trademanager ID: cn200536006, http://bestoilpurifier.bossgoo.com, http://www.zhongnengcq.cn )
● Keywords/Tags:
Oil reclamation system | Oil regeneration system | Oil purification system | Oil filtration system | Oil degassing | Transformer oil purification system | Transformer oil purification | Turbine oil reclamation system | Turbine oil regeneration system | Transformer oil filtering | Turbine oil treatment | Electric supply | Transformer repair and maintenance | Transformer oil re-processing
● Reliability of hydraulic and lubrication systems and the life of system components and fluids are extended by minimizing fluid oxidation, maintaining lubricity properties and reducing aeration. Corrosion within the fluid system can also be controlled by reducing the formation of acids.
● We offer a full line of oil purifiers/ oil purification systems/ oil recycling systems/ oil filtration systems, allowing for you to choose the model best suited for your application. Our oil purifiers (oil dehydrators) can help you realize a wide range of opportunities for savings:
? Extension of fluid life
? Improved productivity
? Purification of collected fluids
? Reduced time for fluid changes
? Less frequent fluid disposal
? Minimized corrosion within fluid systems
? Increased equipment reliability
● Our oil purifiers/ oil purification systems/ oil recycling systems/ oil filtration systems remove 100% of free water and as much as 80% of dissolved water. They also remove 100% of free and entrained gases and up to 80% of dissolved gases. Particulate removal is achieved using a high performance, Beta rated (ßX(c)>1000) filter element to polish the fluid before discharge back to the system reservoir.
● Our oil purifiers/ oil purification systems/ oil recycling systems/ oil filtration systems can be moved from one system to another or left as a permanent installation. Automatic controls, integral to the unit constantly monitor the operation and will safely shut down the system if fluid levels and pressures are outside normal limits.
Our special oil purifiers/ oil purification systems/ oil recycling systems/ oil filtration systems have been designed to be robust and reliable under the most arduous of conditions. All components are easy to maintain and filter elements are readily accessible
● Contact me for more information if you are interested. Thanks !
