(Pinpoint Laser Systems: Peabody, MA) -- Pinpoint Laser Systems is introducing the new Pinpoint Proline Alignment Kit, a visual laser system for checking and measuring straightness, flatness, squareness, parallelism, leveling, and many other attributes. This kit combines the features of a transit, an infinitely long straightedge, and a laser alignment system all in one compact, portable, product. Precision laser alignment for production, maintenance, and plant-engineering projects, large or small, is greatly enhanced by this system.
The Proline Laser produces a crisp, collimated laser reference beam that forms a bull’s-eye pattern for easy visual alignment and precise measuring. The laser is enclosed within a precision-machined housing, ensuring that the laser reference beam is parallel to the side and base surfaces to within 0.003° or less than 0.030 in. at 50 ft. This level of accuracy is ideally suited for setting straight machinery runs, aligning production equipment, transferring mechanical points, locating shafts and bearing mounts, aligning belts and pulleys, and countless other industrial tasks.
