(L.S. Starrett Co.: Athol, MA) -- The L.S. Starrett Co. recently introduced Automotive Inspection Kits to help mechanics measure the proper distance or alignment between parts in a tightly confined space. While the two new inspection sets are ideal for measuring the amount of front-end play or ball-joint wear, for example, they also can check part movement associated with other applications. The two inspection kits combine a highly flexible configuration with several options to allow mechanics to secure the measurement fixture to whatever surface is available.
