(Mettler-Toledo Inc.: Greifensee, Switzerland) -- The International Organization of Legal Metrology (OIML) defines positive and negative tolerance ranges for weights. Traditional weight manufacturing with mechanical weight polishing normally targets the zero line. METTLER TOLEDO is the first manufacturer to apply a unique electrolytic adjustment process featuring fine-tuning in the upper part of the positive tolerance range. Because weights become lighter over the course of their use, the main benefit is obvious: A far longer life span with the stability of the weight value guaranteed.
