You are desperate to know more snoring remedies as the problem has started to create havoc in both your personal and professional life. While relationships are at stake because of your persistent snoring, you feel sleepy and edgy the whole day at office, because you just cannot get good sleep at night. You seem to be running out of options with ways to fall asleep fast.
Your sense of desperation is understandable. While there is no dearth of ways to fall asleep fast, at times nothing seems to work. As far as you are concerned, none of the conventional snoring remedies seem to be effective perhaps because the severity of your condition is such that it might call for a snoring surgery – otherwise known as somnoplasty procedure.
However, you need to understand that surgery is perhaps the last option amongst several snoring remedies and this is the last resort for the doctor to treat you. Before surgery is even considered the snoring doctor would normally tend to recommend one of the following common snoring remedies:
• Weight loss
• Quitting alcohol and tobacco
• Change of sleeping posture from the back to the sides
• Sleeping on a raised pillow
• Using anti-snoring devices including chin straps, anti-snoring pillows, CPAP machines, nose strip, etc.
It is a fact that the snoring remedies mentioned above normally provide effective ways to fall asleep fast for many snorers. But, depending on the location of the obstruction that is blocking the air passage, the severity of snoring and of course the patients’ overall health condition, the doctor may eventually decide on somnoplasty procedure, the most effective choice of surgery to cure snoring.
Somnoplasty procedure: what you should know
This procedure is approved by the FDA for the treatment of habitual snoring, nasal congestions, and also for more serious conditions like sleep apnea. The technology, called the radiofrequency tissue ablation, was originally developed by Somnus Technologies of California.
Somnoplasty procedure involves using a low intensity pre-heated electrode, called the Somnus device, to burn some obstructive tissues responsible for causing impedance to normal breathing. Such tissues could be located in the tongue, inside the nose, soft palate or the throat. The burnt tissues gradually get re-absorbed and the air passage is cleared. The primary aim of somnoplasty procedure is to stiffen and shrink the excess tissues so that they do not collapse while the person is sleeping. Once the volume of excess tissues is reduced, the air passage is automatically cleared of obstructions.
Performed with either local or general anesthesia, the surgery takes not more than 45 minutes to be completed. Though this is one of the most effective snoring remedies in the surgery category, the somnoplasty procedure may not always cure the snoring condition in one session. Depending on the location of the obstruction and the severity, the doctor may also advise subsequent procedures to completely cure the snoring problem.
While there is no paucity of ways to fall asleep fast, surgery is one of the last options for curing snoring. But if you know the details of somnoplasty procedure, you can approach the therapy with an open mind, and more importantly without feeling scared.
Author Bio:
Marc MacDonald is an independent researcher who has spent considerable time and effort in studying and collating information about health-related concerns, specifically focused on sleep and nutrition.
He has written innumerable research reports on particular subjects like somnoplasty, becoming a vegetarian, becoming vegan, eating raw food, deviated nasal septum surgery, snoring remedies, and somnoplasty procedure
To learn more about this article's main topic, please visit his website: http://www.snoreremedies.org/
