(GE Measurement & Control Solutions: Huerth, Germany) -- The new DMS Go from GE’s Inspection Technologies is a high-end thickness gauge that provides accurate and comprehensive thickness-inspection data in a range of selectable formats. It incorporates joystick control, a high all-round visibility, and high-resolution color display. With its robust, dust- and waterproof construction, light weight, operability with a range of thickness probes, and measurement stability at temperatures up to 600° F, it is ideally suited for measuring for corrosion in the oil and gas sector, and in power generation.
