(Mahr Federal: Providence, RI) -- Mahr Federal has introduced a new MarCheck measuring and evaluation unit for its high-precision Linear 100 universal length-measuring instrument. MarCheck allows both measurements and calibrations to be performed quickly and reliably at the touch of a button. Results are clearly shown in large digits on the display screen and can be output via USB or RS-232 ports. With a direct measuring range of up to 50 mm (2 in.) and an application range of up to 100 mm (4 in.), the Mahr Federal Linear 100 provides rapid, accurate internal and external measurements directly on the shop floor.
“The MarCheck evaluation unit makes the Linear 100 even more versatile for precision measurement on the shop floor,” says George Schuetz, Mahr Federal’s director of precision gauges. “In addition to performing submicron measurements, the Linear 100 with MarCheck now helps precision machinists save time by performing calibration checks, such as setting direct-reading measuring equipment or two-point bore gauges.”
