(Eriez: Erie, PA) -- Eriez, a global leader in advanced technology for magnetic, vibratory, and inspection applications, announces the availability of the Eriez Pull Test Kit. When used properly, the kit will help users monitor the efficiency of their magnetic separator by measuring the holding force of a magnet.
The Eriez Pull Test Kit includes:
• A graduated scale
• Four nonmagnetic spacers: one 1/4 in., two 1/2 in., and one 1 in. thick (one 6 mm, two 12 mm, and one 25 mm)
• One 1/8 in. × 1 in. × 3 in. (3 mm × 25 mm × 76 mm) steel plate
• One 1/8 in. × 1 in. × 3 in. (3 mm × 25 mm × 76 mm) steel plate with attached radius nonmagnetic spacer
• One 1 in. diameter (25 mm) steel ball
• One 1/4 in. diameter (6 mm) steel ball
All components come housed in a hard plastic case. The kit is designed for use on a variety of magnetic separators. Certain accessories may not apply to some users’ separators.
“While we use the Pull Test Kit as a quality assurance device, we list typical pull-test values to guide users in their inspection,” explains Bill Dudenhoefer, manager of Separation Products.
