(LUDECA: Doral, FL) -- LEVALIGN EXPERT provides an accurate and easy-to-use method for the measurement of split machine casings, the flatness and straightness of machine bases and foundations, and the flatness and parallelism of circular, rectangular, and odd-shaped flanges. The system consists of a self-leveling, motorized, rotating laser and a sensor that interface wirelessly with a dedicated geometric measurement computer.
The surface profile of the measured component is displayed with full-color 3-D graphics for better evaluation of the results. Powerful features, such as InfiniSplice, allow for the merging of files and the freedom of repositioning the rotating laser to another location during measurement to overcome obstructions to line of sight and to measure complex shaped surfaces.
Surface flatness measurement using LEVALIGN is simple and straightforward—only a single operator is needed to measure large vertical and horizontal surfaces.
LEVALIGN EXPERT is ideal for maintenance departments, field service crews, contractors, and original equipment manufacturers (OEMs).
