Mobile Surface Roughness Measurement for Production Lines
Hommel-Etamic W5 is light, compact, and battery-powered
Jenoptik Industrial Metrology
Tue, 07/26/2011 - 14:13
(Jenoptik: Jena, Germany) -- Light and compact in design, easy to operate with long-lasting battery power, the Hommel-Etamic W5 surface roughness measuring system is ideally suited for measurements on the production line. Capable of a wide range of measuring tasks using an extensive array of probes and accessories, the W5 can match the performance of more expensive stationary systems with its accuracy and precision.
The Hommel-Etamic W5 is ergonomically designed, making it simple to precisely position on the workpiece. The W5 is capable of tracking five separate measurement programs, up to 100 separate profiles, and has a total storage capacity of up to 10,000 completed measurements.
The integrated click wheel allows the operator to intuitively select device functions. In conjunction with the large color display with graphic interface, this makes operating the W5 simple and transparent. Easy-to-see results and tolerance evaluations are delivered every time.
More than 800 measurements with one battery charge guarantee a high level of reliability even during frequent use. Measuring results may be quickly printed out on the optional printer via wireless Bluetooth technology.
