COMET consortium member Nikon Metrology helps transform industrial robots into precision machine tools
The EU co-funded COMET consortium is creating a revolutionary solution enabling the use of industrial robots for high-end machining. Robots of any brand fitted with the novel COMET plug-and-produce controller unit successfully respond to manufacturing industry needs for cost effective, flexible and reliable manufacturing solutions. Nikon Metrology is a main contractor developing an adaptive tracking system to detect deviations from the programmed robot path. These are used to initiate real-time tool path corrections in order to maintain the targeted accuracy throughout the entire machining sequence. The proposed COMET solution will be on average 30% more cost effective than dedicated machine tools, while delivering absolute positional accuracy better than 50 micron.
Industrial robots – a good idea?
To remain competitive, high-end manufacturing companies in Europe are looking for accurate, reliable and maintenance-free machine tools offering fast changeover, programming and setup. Industrial robot technology could provide an excellent base for machining because it is flexible and affordable.
Combined with enabling metrology solutions, industrial robots offer distinct advantages over expensive specialty equipment designed for specific machining tasks. As part of the COMET project, Nikon Metrology is responsible for developing an ADAPTIVE TRACKING SYSTEM. It helps adjust real time robot arm positioning in relation to where it should be according to the initial programmed robot path.
The adaptive tracking system tracks the location of the robot head in real time, and feeds back the metrology data using a closed feedback loop via the controller. This innovative metrology-adjusted process firmly increases robot accuracy because it nearly eliminates the influence of robot warm-up, drift and backlash. It underlines the importance of the adaptive tracking system in transforming industrial robots into precision tools for milling, deburring and other machining applications. There is high demand for such robots in aerospace and automotive markets as well as manufacturers involved with mold & die and high-precision parts.
Real-time robot motion adjustment
The novel COMET robot control system also allows modules other than the adaptive tracking system module to be plugged in. The other modules focus on kinematic and dynamic models to set up a unique robot fingerprint, a holistic programming and simulation environment, and a high dynamics compensation mechanism to eliminate remaining positional errors. In total 14 partners from industry, research institutes and universities collaborate to make this truly innovative European project a success. The COMET plug-and-produce controller is a modular system that fits most robot brands, including ABB, Fanuc and KUKA.
The adaptive tracking system module consists of two components: the tracking system and the comparison and path adaptation module. Most of the available tracking systems are not suitable for use in the COMET project, considering both technical and economic system aspects. Based on specific project needs, the tracking system research will start from the K-Series Optical CMM from Nikon Metrology.
K-series’ pre-calibrated solid state camera system consists of 3 linear built-in charge coupled device (CCD) cameras. With cylindrical lenses on all cameras and the middle camera tilted 90 degrees, the optical CMM measures the locations of infra-red light emitting diodes (LEDs) mounted on the robot head. As a LED is located where the 3 CCD observatory planes intersect at the instance of capture, the system is able to determine the point coordinates based on the plane inclination angles. The K-Series system offers the means to track multiple LEDs simultaneously with 6 degrees of freedom at a sample rate up to 1000 Hertz to allow for dynamic measurements.
The module for the corrective adaptation continuously compares the measured position, speed and acceleration with the corresponding data in the part program. A model-based algorithm will then decide when and how to adjust robot operation to meet the accuracy required by the machining process. Development efforts from Nikon Metrology engineers concentrate on measuring accuracy, system latency and module interfacing in order to obtain precise and prompt robot motion adaptations.
Ready for use with any industrial robot cell
The flexibility and cost efficiency of industrial robots is utilized by adding absolute position accuracy, and a plug-and-produce software environment to design, program, simulate and execute high-end machining processes. New innovative tracking components and modular ICT-based methods are being developed to open new application areas for industrial robots. These components and methods can be plugged in the modular COMET plug-and-produce platform, ready for use with any industrial robot cell.
The 30-month COMET project was kicked off in September 2010, and currently progresses as planned. After completing the COMET plug-and-produce robot controller, Nikon Metrology will act as a partner in exploiting the project results. Nikon Metrology’s Metrology Integrated Robotics center of excellence will play a pivotal role for customers and robot cell integration companies.
The project involves 14 technical partners from 8 countries across Europe, coordinated by UK-based manufacturing software specialists Delcam. For more news and regular updates, check out www.comet-project.eu or follow the project’s developments live on our Twitter account (@Comet_project).
rob.snoeijs@nikonmetrology.com for more info.
