Application:
ZYM is vacuum transformer oil filtration plant, which is special for treating various insulating oil, it can remove water, gas, impurity from insulating oil effectively, Improve oil performance, treated oil will reuse again. ZYM Mobile transformer oil purifier, It is very good for outdoor working, like the outdoor transformer oil treatment, ZYM is easy to move the far-way place, it is waterproof, dustproof.
Features:
1. Mobile (trailer) type, completely closed structure, waterproof, dustproof, move easy.
2. Installation of car tyres, Bridge shock absorber, braking system and steel welding of entire trailer guarantee 60km/h speed.
3. Dealing with unqualified insulating oils, rapidly remove water, gas, particles from oil
4. Multi-stage precision filtration system, mesh filtration combined with molecular adsorption technologies
5. Efficient electric heating system, heating uniformity, less power consumption, safe, and reliable.
6. Double-infrared liquid level sensor, pressure protective system to ensure machine operation easy and safely.
7. Adopt interlocked protective system, which connect oil pump, heater and liquid level sensor, avoiding blank heating, blank pumping, oil leak and electricity leak. If there is any fault, machine will be power off automatically.
Advantages:
Mobile (trailer) type, completely closed structure, waterproof, dustproof, it can move long distance working in field.
Technical Parameters:
Index name
Unit
ZYM-30
ZYM-50
ZYM-65
ZYM-100
ZYM-150
Flow rate
L/H
1800
3000
4000
6000
9000
Working vacuum
MPa
-0.08~-0.099
Working pressure
MPa
<0.4
Temperature range
C
20 -80
Dielectric strength
KV
> 70
Water content
ppm
< 3
Gas content
< 0.1
Particles size
μ
<1
Power supply
380V 50HZ 3Ph (As per user's option)
Working noise
dB(A)
≤65~85
Heating power
Kw
30
30
78
95
110
Total power
Kw
35.5
37.5
87
104
121
