(Cognex: Natick, MA) -- Cognex Corp. has announced a new wireless version for its next-generation DataMan handheld industrial ID scanner, the DataMan 8000 series. The wireless communication module and base station with Cognex Connect capabilities is now available for extended-range, cord-free code reading applications. Cognex Connect provides the most flexibility for communicating via Industrial Protocols such as EtherNet/IP, PROFINET, MC Protocol, and others, in addition to traditional support for USB and RS-232. The DataMan 8000 series is the only industrial handheld ID reader to support industrial protocols for both corded and cordless models, allowing for easy integration, reduced installation costs, and remote access to diagnostics.
The wireless reader provides a long working range—up to 100 m—with a large memory capacity for reading codes when offline or out of range. The base station comes standard with a spare battery charger built in and is compatible with industry-standard Ethernet, USB, and RS-232 cables.
