Ball Mill is mainly used to grind materials in mineral, cement, refractory, chemical industry, etc. Ball Mill has dry and wet ways. When wet Ball Mill works, certain water and other liquid will be added with materials to increase materials liquidity, so the capacity is increased. When dry Ball Mill works, the reduced material liquidity will influence the productivity. So absorbing wind device is needed on the outlet of Ball Mill, and then negative pressure is formed inside the Ball Mill to increase flow ability of material, at last the capacity is increased.
Working principle: When the Ball Mill works, motor and speed reducer transmit torque force to gear and pinion of Ball Mill to let the barrel rotates. The revolving ball mill lifts steel balls or other grinding media to a certain height and fall down freely to crush the materials continuously until the materials up to the needed fineness. Due to flow ability of material, the final product will be discharged from outlet to finish the grinding.
Features: 1. Large application range, simple structure and convenient maintenance; 2. Large capacity and continuous work are obvious advantages; 3. Various barrel lining and grinding media, excellent corrosion resistance; 4. Installation and adjustment are very convenient and easy to operate.
