Circular Vibrating Screen is main equipment to separate solid materials. It is widely used in mineral, building materials, coal dressing, energy, chemical industry, etc.
Working principle: Circular Vibrating Screen produces vibrating force by vibrating generator, it makes screen body vibrate periodically based on vibrating direction. Various size of materials are separated and transported to specified places according to different sieve mesh.Vibrating frequency can be adjusted by adjusting eccentric block's weight.
Features: 1. Using eccentric block as vibrating source, so vibrating force is very strong; 2. Two screen states apply top-grade quality pipes materials and special high strength bolts and professional welding technique to make the screen durable; 3. Layer quantity of sieve is depends on customers’ request; 4. High separating efficiency, large capacity, long using life, low power consumption and tiny noise; 5. Applying two sides tensioning technique to fasten screen, structure is simple and sieve mesh replacement is convenient.
