Normal
0
7.8 磅
0
2
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:普通表格;
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Features Of Mobile Crusher in my company Shanghai Joyal Mining Machinery Co., Ltd.:
1. Move easily.It can go to the crushing place where is difficult to go. It not only can drive on the smooth road, but also on the bumpy road.
2. Compact structure and simple operation. Integrative equipment group with trailer saves the working area. With generator, motor and control box, it can work in any place even there is no electricity. With supporting equipment on the trailer, so no need to install the machine.
3. Save the cost. Crush the materials on site, reduce the transportation cost.
4. Wide application. The crushing plant can work as independent unit; work with other unit to do primary and secondary crushing; work with two other units to do primary, secondary, and fine crushing; working as a production line with the screening equipment (firstly screening then crushing, or firstly crushing then screening.)
5. Good performance and convenient maintenance. The crushers, vibrating feeders, and vibrating screens are from Shanghai Joyal Heavy Industry, so the quality is reliable and stable. Material is delivered by belt conveyors, which is simple in operation, easy maintenance, and low investment.
6. Flexible configuration. Can provide suitable portable crushing plant based on customers working site, material typical, and particle shape requirement. Such as single unit, combined units, self-load belt conveyor unit and so on.
Main Specifications Of Mobile Jaw Crusher:
Model
Vibrating feeder
Jaw crusher
Belt conveyor
Extended belt conveyor
Capacity (t/h)
Power (kw)
Max
Dimension L×W×H(mm)
Total weight(t)
YG938E69
GZD960×
3800
PE600×900
B650×7M
Optional
70-150
91.5
13200×
2900×
4700
42
YG1142E710
GZD1100×
4200
PE750×1060
B800×9M
Optional
90-200
134
15000×
3100×
5100
55
YG1349E912
GZD1300×
4900
PE900×1200
B1000×11M
Optional
150-300
146
17000×
3300×
5600
72
Main Specifications Of Mobile Impact Crusher:
Model
Vibrating Screen
Impact Crusher
Belt Conveyor
Capacity (t/h)
Power (kw)
Overall Dimension
L×W×H (mm)
weight
(t)
Y3S1548F1010
3YZS1548
PF1010
B500×7M
50-250
70-90
12500×
2800×
6000
42
Y3S1848F1210
3YZS1848
PF1210
B650×7M
70-300
128.5-150.5
12500×
3000×
6500
46
Y3S1860F1214
3YZS1860
PF1214
B650×8M
90-400
154-190
13500×
3000×
6500
51
Y3S2160F1315
3YZS2160
PF1315
B800×8M
120-450
210-297
14000× 3200×
6800
57
Main Specifications Of Mobile Cone Crusher:
Model
Vibrating screen
Cone crusher
Belt conveyor
Capacity (t/h)
Power (kw)
Max Dimension
L×W×H (mm)
Total
weight
(t)
Y3S1548Y900
3YZS1548
PYB900
B500×7M
50-200
75
13000×
2800×
6400
43
Y3S1848S36
3YZS1848
ZYS36
B650×7M
70-300
99-134
13000×
3000×
6700
47
Y3S1860S51
3YZS1860
ZYS51
B650×8M
120-400
212.5-220.5
14000×
3000×
6700
53
Y3S2160H220
3YZS2160
HP220
B800×8M
140-450
257.5-264.5
14000×
3200×
6700
58
