Application:
Video measuring system is suitable for electronic, molding, press, spring, screw, tool, plastic, rubber, valve, camera, bicycle, motor parts, PCB, conduction rubber, interference board, lead frame and other precision industries.
Specification:
Model No.
MV-1510
MV-2010
MV-3020
MV-4030
Travel-X.Y axis
150*100(mm)
200*100(mm)
300*200(mm)
400*300(mm)
Travel-Z axis
150
150
150
150
Stage size
354*228
404*228
500*330
606*466
Stage load capacity
30kg
35kg
Dimension L*W*H
540*560*850
540*560*850
760x600x900
970x670x940
Net weight
98kg
108
138
238
Features:
• Video system: high resolution video camera
• Magnification: 0.7X~4.5X(28X~180X); optional: 0.5X, 2X, object lens
• Illumination: adjustable illumination for surface and contour
• Power supply: AC110-120v, 200-240v, 50HZ, 30W
• Linear scale-X. Y .Z axis: 0.05µm resolution
• Digital readout: MC800 DRO systems with RS232 output
• Accuracy: ±(3+L/75)µm, of which, L = length of the work piece measured ( unit: mm)
• Repeatability: 0.003mm
• Sighting device: cross-hair
• Software: 2D Measurement software
