Usages:
This optical comparator is a precision measuring device integrating optics, mechanics, electricity and computation into an organic whole; which is widely used in the labs, college RD, measuring rooms and workshops of related factories and plants in the sectors such as metal mould, clock and watches and electronics industries. This instrument can easily and speedily check the profiles and surface shapes of various measured jobs; e.g., various parts, cutting tools, punching pieces, cams, gears, molding milling cutters, tapping tools, etc.
Paramters:
Illumination
CONTOUR
SURFACE
Magnification
10X
20X
50X
100X
10X
20X
50X
100X
View field diameter
30.6
15.3
6.1
3
30.6
15.3
6.1
3
Working distance (L)
73
68
26
25
23
29
6
5
Max.workpiece height (H)
80
80
80
80
80
80
80
80
Max.workpiece diameter whose edge line can be focused on the screen center (D)
140
140
60
55
140
140
48
45
Specification:
• Screen size: ¢312mm with 4 film clips
• Image: erect and un-reversed
• Stage load capacity: 10kg
• Net weight: 100kg
• Object lens:
10x.20x.50x.100x. (standard 10x), reflector attached
• Magnification accuracy: 0.08% contour, 0.12% surface
• Illumination: 24v/150w halogen bulbs for contour and surface
• Power supply: AC110-120v, 200-240v, single phase 50/60Hz
• Linear scale-X. Y axis: 0.05µm resolution
• Accuracy: ±(4+L/25)µm, L = length of the work piece measured ( unit: mm)
• Repeatability: 0.003mm
• Transmission: linear guide, fits fast moving
• Digital readout: MC800 Counter with RS232 output
• Features:
(1) skew
(2) mm/inch conversion
(3) ABS/INC conversion
(4) Zero setting
(5) 1/2 calculation
(6) 0° 90° 270° 360° conversion
(7) Linear compensation
(8) RS232 output
