Model No.
VOL Series
Erect and un-reversed(positive)
Illumination
CONTOUR
SURFACE
Magnification
10X
20X
50X
100X
10X
20X
50X
100X
View field diameter
30.6
15.3
6.1
3
30.6
15.3
6.1
3
Working distance (L)
77.7
44.3
38.4
25.3
23
29
6
5
Max.workpiece height (H)
90
90
90
90
90
90
90
90
Max.workpiece diameter whose edge line can be focused on the screen center (D)
200
200
60
55
170
160
48
45
Specification:
• This profile projector has an upand down the project lens to focus
• Screen size: ¢312mm with 4 film clips
• Travel-X.Y axis: 250mm*150mm
• Stage size: 450mm*280mm
• Stage load capacity: 50kg
• Net weight: 175kg
• Object lens:10x.20x.50x.100x. (standard 10x), reflector attached
• Magnification accuracy: 0.08% contour, 0.12% surface
• Illumination: 24v/150w halogen bulbs for contour and surface
• Power supply: AC110-120v, 200-240v, single phase 50/60Hz
• Linear scale-X. Y axis: 0.05µm resolution
• Angle measuring: 0.01°or 1′resolution
• Accuracy: ±(3+L/75)µm, of which, L = length of the work piece measured ( unit: mm)
• Repeatability: 0.003mm
• Transmission: linear guide, fits fast moving
• Digital readout: MC800 DRO with RS232 output
• Printer: Build-in printer
• Features:
(1) skew
(2) mm/inch conversion
(3) ABS/INC conversion
(4) Zero setting
(5) 1/2 calculation
(6) 0° 90° 270° 360° conversion
(7) Linear compensation
(8) RS232 output
Standard accessories of the Profile Projector
1. Data processor
2. One lens
