Turret Profile Projector
VOM series turret profile projector owns high quality optical measuring performance. There is a rotary lens turret which can equip with three different lens. When working in different magnifications, users can rotate the lens, instead of changing lens individually, which enhance the measurment efficiency largely
Objective Lens
Magnification
10X(Standard)
20X(Optional)
50X(Optional)
100X(Optional)
Objective View(mm)
Ф30
Ф15
Ф6
Ф3
Working Distance(mm)
77.7
44.3
38.4
25.3
Max. Workpiece height
90mm
90mm
90mm
90mm
Specification:
• Screen size: ¢312mm with 4 film clips
• Image: erect and un-reversed
• Net weight: 100kg
• Object lens:10x.20x.50x.100x. (standard 10x), reflector attached
• Magnification accuracy: 0.08% contour, 0.12% surface
• Illumination: 24v/150w halogen bulbs for contour and surface
• Power supply: AC110-120v, 200-240v, single phase 50/60Hz
• Linear scale-X. Y axis: 0.05µm resolution
• Accuracy: ±(4+L/25)µm, L = length of the work piece measured ( unit: mm)
• Repeatability: 0.003mm
• Transmission: linear guide, fits fast moving
• Digital readout: MC800 DRO with RS232 output
• Features:
(1) skew
(2) mm/inch conversion
(3) ABS/INC conversion
(4) Zero setting
(5) 1/2 calculation
(6) 0° 90° 270° 360° conversion
(7) Linear compensation
(8) RS232 output
