Contact: Abby Liao
Email: topoilpurifier@gmail.com
T/F: +86-23-88901306
Skype ID: topoilpurifier
Yahoo messenger ID: topoilpurifier@yahoo.com
MSN/Live/Hotmail ID: topoilpurifier@hotmail.com
Gtalk ID: topoilpurifier@gmail.com
Application:
Series TYF is latest model of vacuum oil purifier designed for purifying the unqualified phosphate ester fire-resistant oil, this machine can treat and regenerate the degenerative fire-resistant oil, removing acid, pigment, gas, water and particles. This machine body uses the special metal materials which are compatible with fire-resistant oil, combined with technologies of vacuum dewatering, multi-stage filtration system and new adsorbent to ensure treated oil achieve new fire-resistant oil properties. Series TYF is the necessary purifying equipment for the sectors which use fire-resistant oil, it can be online working and oil-filling.
Features:
Use of special metal materials which is compatible with fire-resistant oil, combined with technologies of vacuum dewatering, multi-stage filtration system and new adsorbent
Stainless steel machine body, pipes and filtering components, reliable, anti-corrosion, durable.
Duplex-Stereo film evaporation technology, equips with unique and advanced dewatering, degassing components, can rapidly and effectively remove water, gas, particles and volatile matter
Advanced medium cooling system
High quality filtering components, large capacity for holding particles, anti-corrosion, good mechanical performance, long lifetime.
6. Efficient electric heating system, heating uniformity, less power consumption, safe, and reliable.
7. Adopt interlocked protective system, which connect oil pump, heater and liquid level sensor, avoiding blank heating, blank pumping, oil leak and electricity leak. If there is any fault, machine will be power off automatically.
Product line:1: Transformer Oil Treatment System2: Lubricating Oil Purification Unit3: Turbine Oil Conditioning System4: Hydraulic Fluids Filtration Machine5 Light Oil (Fuel) Filtering Unit
6: Engine Oil Regeneration Plant7. Vegetable Oil Purifier8. Heat Transfer Oil Purifier9. Centrifugal Oil Filtration Unit
10. Plate pressure oil purifier
11. Portable oil filtering and oiling machine
12. Vacuum dehydrator
13. Explosion protection filtration machine14.. Oil Analyzer
