Terms of Use
I agree to the terms of use:
document
 Contact: Abby Liao
Email: topoilpurifier@gmail.com
      sales@topoilpurifier.com
T/F: +86-23-88901306
Skype ID: topoilpurifier
Yahoo messenger ID: topoilpurifier@yahoo.com
MSN/Live/Hotmail ID: topoilpurifier@hotmail.com
Gtalk ID: topoilpurifier@gmail.com
Http://www.topoilpurifier.com
Application:
Series ZY high vacuum insulating oil purifier, is specially designed for purification of aging transformer oil, mutual inductor oil, switch oil, capacitor oil as well as for other electrical insulating liquids. The process maintains the oil's dielectric strength, removes free, soluble water, air-gases and particulate matter.
Features:
1. This machine is small, hi-efficient conveniently. And it can live operated with electrical, vacuum oiling the power equipment and dry moisture of power equipment.
2. Duplex-Stereo film evaporation technology, combined with unique and advanced dewatering, degassing components, can rapidly and effectively separate water, gas from oil.
3. Efficient electric heating system, heating uniformity, less power consumption, safe, and reliable.
4. Double-infrared liquid level sensor, pressure protective system to ensure the machine operation easy and safely.
5. Adopts interlocked protective system, which connect oil pump, heater and liquid level sensor, avoiding blank heating, blank pumping, oil leak and electricity leak. If there is any fault, machine will be power off automatically.
6. Working with BZ insulating oil regeneration device to decolor (remove acid, oxide, free carbon) and lower dielectric loss, making the treated oil more limpidity.
Advantages:
Series ZY is efficient and economical insulating oil purifier. Doplex-Stereo film evaporation technology, unique and advanced dewatering, degassing components, making working efficiency is 3-5 tims than traditional oil purifier. Machine adopts interlocked protective system, double-infrared liquid level sensor and pressure protective system to make sure the machine work unattended, operation easy, safe and reliable.
(oil purifier, oil purification, oil filtration, oil recycling, oil treatment, oil regeneration, oil restoration, oil filtering, waste oil disposal, oil reclaiming, waste oil management, energy saving, oil reconditioned, oil reconstituted, oil restituting, oil recovering ,oil filtration, oil filter, petroleum machine)
Product line:1: Transformer Oil Treatment System2: Lubricating Oil Purification Unit3: Turbine Oil Conditioning System4: Hydraulic Fluids Filtration Machine5 Light Oil (Fuel) Filtering Unit
6: Engine Oil Regeneration Plant7. Vegetable Oil Purifier8. Heat Transfer Oil Purifier9. Centrifugal Oil Filtration Unit
10. Plate pressure oil purifier
11. Portable oil filtering and oiling machine
12. Vacuum dehydrator
13. Explosion protection filtration machine14.. Oil Analyzer
