Terms of Use
I agree to the terms of use:
document
Contact: Abby Liao
Email: topoilpurifier@gmail.com
      sales@topoilpurifier.com
T/F: +86-23-88901306
Skype ID: topoilpurifier
Yahoo messenger ID: topoilpurifier@yahoo.com
MSN/Live/Hotmail ID: topoilpurifier@hotmail.com
Gtalk ID: topoilpurifier@gmail.com
Http://www.topoilpurifier.com
Series TY is widely used for filtering turbine lubricating oil in electric power, metallurgical, chemical engineering industries. It is good at emulsion breaking, dehydration and removing soap, gelatin, acid, pigment and metal particulates in emulsified turbine oil and low-viscosity lubricating oil as well as turbine oil used in other machinery and electric power equipment.To meet customers' special needs, we designed
TY-A Automatic turbine oil purifier,
TY-M Mobile turbine oil purifier,
TY-E Ex anti-explosion turbine oil purifier
 for different requirements and working conditions.
1. It adopts the coalescence and separation and Duplex-Stereo film evaporation technology, equips with unique and advanced dewatering, degassing components, can rapidly and effectively separate water, gas from oil.
2.       Optimized electric heating system with automatic constant temperature controller ensures the oil temperature to be even and stable.
3.       Precise multi-stage filtration system helps remove different kinds of impurities with high quality filter element of better ability of containing pollutants and long service life.
4.   Advanced infrared oil level control system and pressure protection device make operation simple and safe.
5. It can purify any kinds of turbine oil used in steam turbine and water turbine online and onsite.
6. Air cooling system helps cool down air and gases from the vacuum vessel so as to extend the service life of vacuum pump, avoiding the inconvenience of water cooling.
7. The machine can also be installed with digital flow meter and timer to calculate and record the volume of output oil and working hours (it's optional).
8. Aluminum electric control cabinet has the merits of heat conducting and anti-explosion.
 (oil purifier, oil purification, oil filtration, oil recycling, oil treatment, oil regeneration, oil restoration, oil filtering, waste oil disposal, oil reclaiming, waste oil management, energy saving, oil reconditioned, oil reconstituted, oil restituting, oil recovering ,oil filtration, oil filter, petroleum machine)
Product line:1: Transformer Oil Treatment System2: Lubricating Oil Purification Unit3: Turbine Oil Conditioning System4: Hydraulic Fluids Filtration Machine5 Light Oil (Fuel) Filtering Unit
6: Engine Oil Regeneration Plant7. Vegetable Oil Purifier8. Heat Transfer Oil Purifier9. Centrifugal Oil Filtration Unit
10. Plate pressure oil purifier
11. Portable oil filtering and oiling machine
12. Vacuum dehydrator
13. Explosion protection filtration machine14.. Oil Analyzer
