It is applied to treat various unqualified insulating oils, including aging transformer oil, mutual inductor oil, switch oil etc. Features: 1. Bi-infrared liquid Duplex 3D stereo-evaporation technology, dewatering and degassing effectively. 2. Distinctive removing the impurities technology of filtering through double FH trapezoidal network and absorbing by high polymer without the mechanical power. 3. Bi-infrared liquid level automatic controller system 4. Trinity inter locked preventive device 5. It can work independently; It can also work with the oil regeneration system 6. It can work as the vacuum oiling machine or vacuum drying machine to the power equipment, like transformer 7. Automatic testing the oil dielectric strength and printing out the result 8. It can work online Advantage It's the new-type of high effective vacuum oil purifier with the duplex 3D stereo-evaporation technology and G technology. Adopting the technology, removes the impurities through double FH trapezoidal network and adsorbs by high polymer without the mechanical power. It's five to eight times more effective than the common vacuum oil purifiers. The consumption of energy is low and it doesn't require other wearing materials. Our Main Products: Series ZY Single-Stage Vacuum Transformer Oil Purifier Series ZYD Double High Vacuum Transformer Oil Purifier Series ZYB Multiply-Function insulating oil treatment machine Series TY Turbine Oil Purification Apparatus Series TYA Lubricating oil/ hydraulic oil purification unit Series LYE Engine oil recycling system Series TYB Portable light Fuel oil purification machine Series PL Plate pressure oil purifier Series TYD Vacuum dehydrator Series EFD Explosion protection filtration machine Series JL Portable oil filtering and oiling machine Series IIJ Oil Tester (BDV Tester) .E-mail: chinaoilpurifier@gmail.com chinaolipurifier@hotmail.com
Terms of Use
I agree to the terms of use:
