Crawler Mobile Crushing and Screening Station is of high cost-performance ratio, and it is reliable in performance and reasonable in structure. Crawler Mobile Crusher applies the advanced technology with the international level. Crawler mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and so on.
Features
1. High cost-performance ratio. 2. Reliable quality and beautifully structured.
Application
Crawler type mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and other fields to crusher and screen.
Mobile Jaw Crusher Crushing Plant:
Vibrating Feeder
GZD-960X3800
GZD-1100X4200
GZD-960X3800
Jaw Crusher
PE600X900
PE750X1060
PE500X750
Main Belt Width (mm)
800
1000
650
Main Belt Discharge Height (mm)
2700
2800
2700
Side Belt Width (mm)
500
650
500
Side Belt Discharge Height (mm)
2700
2900
2700
Power (KW)
150
220
150
Transportation Length (mm)
13000
14000
12500
Transportation Width (mm)
3050
3180
3050
Transportation Height (mm)
3500
4300
3400
Transportation Weight (T)
39
54
33
Mobile Impact Crusher Crushing Plant:
Vibrating Feeder
GZD-960X3800
GZD-960X3800
GZD-960X3800
Impact Crusher
PF1010
PF1210
PF1214
800
800
1000
2700
2700
2700
500
500
500
2700
2700
2700
Power (KW)
150KW
200
300
12000
13000
13000
3050
3050
3050
3500
3800
3800
36
42
48
Mobile Cone Crusher Crushing Plant:
Cone Crusher
ZYS36
ZYS51
HP220
Vibrating Feeder
GLD1500/4
GLD1500/5
GLD1500/5
Up Hopper Volume (M3)
4
5
5
Feeding Height (mm)
2700
2900
2900
800
1000
1000
2700
2800
2800
Power (KW)
150KW
300KW
400KW
12000
12500
12500
3050
3050
3050
3700
3900
3900
38
45
50
Mobile Vibrating Screen Crushing Plant:
Vibrating Screen
2ZS1848
3YZS1860
3YZS2160
Closed hopper volume (M3)
5
6
8
Closed hopper Height (mm)
4300
5000
5000
Feeding Belt
B800X7.2
B1000X8.5
B1000X8.5
Screen Under Belt
B800X7
B1000X8
B1000X8
Screen Under Belt Discharge Height (mm)
3500
3500
3500
Side belt
B500X5
B650X5
B650X5
Side belt Discharge Height (mm)
3500
3500
3500
Front Belt
B650X7
B800X8
B800X8
Front Belt Discharge Height (mm)
2800
3000
3000
Power (KW)
120
150
180
12000
13500
1400
3050
3200
3400
3500
4100
4100
30
36
42
