Introduction of Crawler Mobile Crusher-Jaw Crusher
Crawler Mobile Crushing and Screening Station is of high cost-performance ratio, and it is reliable in performance and reasonable in structure. Crawler Mobile Crusher applies the advanced technology with the international level. Crawler mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and so on.
Features
1. High cost-performance ratio. 2. Reliable quality and beautifully structured.
Application
Crawler type mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and other fields to crusher and screen.
Vibrating Feeder: GZD-960X3800, GZD-1100X4200, GZD-960X3800 Jaw Crusher: PE600X900, PE750X1060, PE500X750 Main Belt Width (mm): 800, 1000, 650 Main Belt Discharge Height (mm): 2700, 2800, 2700 Side Belt Width (mm): 500, 650, 500 Side Belt Discharge Height (mm): 2700, 2900, 2700 Power (KW): 150, 220, 150 Transportation Length (mm): 13000, 14000, 12500 Transportation Width (mm): 3050, 3180, 3050 Transportation Height (mm): 3500, 4300, 3400 Transportation Weight (T): 39, 54, 33
