Introduction of Joyal Crawler Mobile Crusher-Impact Crusher
Crawler Mobile Crushing and Screening Station is of high cost-performance ratio, and it is reliable in performance and reasonable in structure. Crawler Mobile Crusher applies the advanced technology with the international level. Crawler mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and so on.
Features
1. High cost-performance ratio. 2. Reliable quality and beautifully structured.
Application
Crawler type mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and other fields to crusher and screen.
Vibrating Feeder: GZD-960X3800, GZD-960X3800, GZD-960X3800 Impact Crusher: PF1010, PF1210, PF1214 Main Belt Width (mm): 800, 800, 1000 Main Belt Discharge Height (mm): 2700, 2700, 2700 Side Belt Width (mm): 500, 500, 500 Side Belt Discharge Height (mm): 2700, 2700, 2700 Power (KW): 150KW, 200, 300 Transportation Length (mm): 12000, 13000, 13000 Transportation Width (mm): 3050, 3050, 3050 Transportation Height (mm): 3500, 3800, 3800 Transportation Weight (T): 36, 42, 48
