Introduction of Joyal CRAWLER MOBILE CRUSHER-Cone Crusher
Crawler Mobile Crushing and Screening Station is of high cost-performance ratio, and it is reliable in performance and reasonable in structure. Crawler Mobile Crusher applies the advanced technology with the international level. Crawler mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and so on.
Features
1. High cost-performance ratio. 2. Reliable quality and beautifully structured.
Application
Crawler type mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and other fields to crusher and screen.
Cone Crusher: ZYS36, ZYS51, HP220 Vibrating Feeder: GLD1500/4, GLD1500/5, GLD1500/5 Up Hopper Volume (M3): 4, 5, 5 Feeding Height (mm): 2700, 2900, 2900 Main Belt Width (mm): 800, 1000, 1000 Main Belt Discharge Height (mm): 2700, 2800, 2800 Power (KW): 150KW, 300KW, 400KW Transportation Length (mm): 12000, 12500, 12500 Transportation Width (mm): 3050, 3050, 3050 Transportation Height (mm): 3700, 3900, 3900 Transportation Weight (T): 38, 45, 50
