Introduction of Crawler Mobile Crusher Screen
Crawler Mobile Crushing and Screening Station is of high cost-performance ratio, and it is reliable in performance and reasonable in structure. Crawler Mobile Crusher applies the advanced technology with the international level. Crawler mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and so on.
Features
1. High cost-performance ratio. 2. Reliable quality and beautifully structured.
Application
Crawler type mobile crushing & screening plant is widely used in road & bridge construction, metallurgy and other fields to crusher and screen.
Vibrating Screen: 2ZS1848, 3YZS1860, 3YZS2160 Closed hopper volume (M3): 5, 6, 8 Closed hopper Height (mm): 4300, 5000, 5000 Feeding Belt: B800X7.2, B1000X8.5, B1000X8.5 Screen Under Belt: B800X7, B1000X8, B1000X8 Screen Under Belt Discharge Height (mm): 3500, 3500, 3500 Side belt: B500X5, B650X5, B650X5 Side belt Discharge Height (mm): 3500, 3500, 3500 Front Belt: B650X7, B800X8, B800X8 Front Belt Discharge Height (mm): 2800, 3000, 3000 Power (KW): 120, 150, 180 Transportation Length (mm): 12000, 13500, 1400 Transportation Width (mm): 3050, 3200, 3400 Transportation Height (mm): 3500, 4100, 4100 Transportation Weight (T): 30, 36, 42
