V Series Hydraulic Jaw Crusher is another big step forward Joyal group has made, on the road to continuously upgrading Joyal crushing equipments. Its crushing efficiency has improved enormously with the innovated cavity design, and the hydraulic system makes possible the high efficiency and smooth operation of the machine. V Series Hydraulic Jaw Crusher are capable of crushing almost all kinds of mining materials, no matter how hard it is, thus enabling it to cast the traditional Jaw Crusher into the shade.
Features
1. Unique heavy-duty design, superior steel plate welded by CO2 gas shielded welding and annealed to be durable; 2. Alloy eccentric shaft, forged and lathed to be superior in bearing capacity; 3. High-quality shaft and oil lubricating to ensure the long service life, smooth running and simple maintenance; 4. Deep crushing cavity and optimized rotating speed well coupled to the angle between fixed and movable jaw plate to ensure the high capacity; 5. Non-lubricant toggle plate to protect the machine from being overloaded; 6. Hydraulically adjustable discharging outlet, simple to operate and maintain, thus achieving the high capacity.
Working Principle
The strip and strip pulley are driven by a motor, and the movable jaw moves up and down via eccentric shaft. The angle between fixed jaw and movable jaw becomes smaller when the movable jaw runs down, then the materials are crushed into pieces. It will become bigger when the movable jaw runs up. The movable jaw board leaves the fixed jaw board under the action of pole and spring , then the end products come out from the crushing cavity.
Model
Max.Feeding Size(mm)
Power(kw)
Capacity(t/h)Close Discharge Size(mm)
Weight(t)
50
70
80
100
125
150
200
225
250
300
VPE400×600
600×400
30-40
26
38
45
60
75
6.32
VPE500×750
750×500
45-60
40
60
70
90
112
130
8.75
VPE500×900
900×500
60-75
45
72
85
100
130
10.5
VPE600×900
900×600
60-75
105
130
160
182
14
VPE750×1050
1050×750
90-115
180
210
237
294
22.5
VPE800×1200
800×1200
115-150
210
250
280
320
350
26.65
VPE1000×1200
1200×1000
130-150
265
302
370
402
44.5
VPE800×1350
800×1350
135-150
250
300
340
420
450
27.77
VPE1000×1500
1500×1000
185-225
310
350
440
480
510
50.38
VPE1200×1500
1500×1200
185-265
415
500
540
580
630
78
The capacity above is tested as per medium hard limestone.
