V Series Hydraulic Jaw Crusher VPE500×900 is another big step forward Joyal group has made, on the road to continuously upgrading Joyal crushing equipments. Its crushing efficiency has improved enormously with the innovated cavity design, and the hydraulic system makes possible the high efficiency and smooth operation of the machine. V Series Hydraulic Jaw Crusher VPE500×900 are capable of crushing almost all kinds of mining materials, no matter how hard it is, thus enabling it to cast the traditional Jaw Crusher into the shade.
Features
1. Unique heavy-duty design, superior steel plate welded by CO2 gas shielded welding and annealed to be durable; 2. Alloy eccentric shaft, forged and lathed to be superior in bearing capacity; 3. High-quality shaft and oil lubricating to ensure the long service life, smooth running and simple maintenance; 4. Deep crushing cavity and optimized rotating speed well coupled to the angle between fixed and movable jaw plate to ensure the high capacity; 5. Non-lubricant toggle plate to protect the machine from being overloaded; 6. Hydraulically adjustable discharging outlet, simple to operate and maintain, thus achieving the high capacity.
Working Principle
The strip and strip pulley are driven by a motor, and the movable jaw moves up and down via eccentric shaft. The angle between fixed jaw and movable jaw becomes smaller when the movable jaw runs down, then the materials are crushed into pieces. It will become bigger when the movable jaw runs up. The movable jaw board leaves the fixed jaw board under the action of pole and spring , then the end products come out from the crushing cavity.
Model: VPE500×900 Max.Feeding Size(mm): 900×500 Power(kw): 60-75 Close Discharge Size(mm)/Capacity(t/h): 50/45, 70/72, 80/85, 100/100, 125/130 Weight(t): 10.5
