(Marsh Bellofram: Newell, WV) -- The compact, rugged and reliable Type 5000 is a two-wire pressure transmitter, expressly designed for industrial field service.
This precision unit converts a signal pressure input into a precise 4-20 mA or 10-50 mA output. The lightweight housing includes a 1/4 NPT pressure port and 1/2 NPT conduit port for field wiring. Connections are easily accessible via top cover removal. Zero and span adjustments are available within the field wiring compartment for fine, on-site calibration adjustment.
Privacy Policy.
