(MetrologyWorks: Buckner, MO) -- MetrologyWorks, the company specializing in all support systems and accessories for portable CMMs, is proud to announce its latest system, the industry-first Rhino Series heavy-duty rolling stand equipped with the SmartModule sensor suite.
Rhino Series stands are easily and affordably updated with a rising column. These stands include the following features:
• Smooth adjustment
• Spring-loaded rack lock
• Air-cushioned moving column
• 3.5-in. 8 universal stainless steel mount ring
• Foot pedal lock
• Heavy-duty casters
• Easy assembly and disassembly
• 100-percent made in the USA
The SmartModule sensor suite is contained in a protective enclosure that enables the operator to monitor temperature, pressure, vibration, and deflection. Visual and audio feedback prompts the operator to check the setup and make the proper adjustments and offsets to realign or scale measurements. This gives the operator the ability to optimize their measurement session and ensures the most accurate results possible when using a portable CMM.
