(DE-STA-CO: Auburn Hills, MI) -- With the new 52H-3E series, DE-STA-CO is offering a very individualized, adjustable manual power clamp primarily for prototype fixtures. The manual power clamps are available in two sizes—50 and 63. They have a completely closed aluminum housing that protects the inner mechanical parts from weld splatters. The opening angle is close to infinitely variable with adjustments from zero to 135 degrees. An Allen key is used to open the retaining mechanism and to clamp it again to the desired setting.
There are two manual levers available that can be mounted on the left or right. While the “H0” model can be installed in different positions, the “HS” model can be welded on as desired, even at an axially bent angle, thus utilizing the ergonomic position. There is a large array of U and side clamping arms available.
