(BEA Lasers: Elk Grove Village, IL) -- The MIL Series laser modules includes the MIL RA Model that features a right angle, and the MIL Compact Model that features a straight housing. Both laser modules are ideally suited for applications with limited space and tight positioning requirements.
Both new MIL Series models utilize a low profile 3/8-in. rugged laser housing, fitted with a M12 connector, 2-meter long PVC jacketed cable, and integrated power supply. The optional sensor-style bracket, or multi-adjustable “LB” bracket, completes the laser system. The new MIL Series laser diode modules are offered with standard 515 nm (green) or standard 635 nm (red), with 1 mW or 5 mW. Other outputs are available on request.
The industry’s first-right angle rugged laser system, the MIL RA is a laser diode module with a 3/8-in. brass, nickel-plated laser housing that only occupies 1.5 in. of valuable space.
The MIL Compact is a low profile laser diode module that occupies 1.5 in. of space, a much smaller profile then other lasers intended for industrial applications.
