(Phillips Precision: Boylston, MA) -- Phillips Precision’s Products Division announces its new 3-Legged Spider Clamp as part of the Inspection Arsenal LEAN, Quick-Swap inspection fixture system. Not only does Phillips Precision offer the only quick-swap standard fixture systems, but it provides quick, creative fixture design and quick shipping of your orders. Inspection Arsenal tooling will help optimize your inspection process and uncover hidden profits.
This unique vise is specifically designed to hold delicate round parts without distortion and allow maximum back lighting for vision inspection (also works well for CMM inspection). Designed to replace bulky, traditional three-jaw chucks that limit access and can distort parts. The Spider Vise is designed to hold parts from 1.18 in. to 6 in. in diameter. Each leg has adjustable pins with o-rings to provide grip when part is in place. Spider-Vise is black anodized aluminum sitting on a ¾ in. x 2 in. steel stand-off secured by a flathead screw. Add taller stand-offs to gain more height when necessary. Available with ¼-20 and M6 mounting thread.
