(Sunnen: St. Louis) -- Sunnen’s PG-700/800 Series bore gages are ideal for fast, simple, economical process control in lean manufacturing environments, combining accuracy with a shop-hardened, all-mechanical design. And Sunnen’s Gage Leasing Program allows shops of all sizes and production runs to have precision in-line measurement for parts that are honed, ground, bored, reamed, or drilled.
The lease program includes maintenance and provides replacement gages, if needed. The popular PG-400 and PG-500 setting fixtures can also be leased to complement the PG gages. The lease renews each year and if the gage is no longer needed at the shop, it is simply returned to Sunnen. If a gage needs to be repaired during the lease, it is quickly swapped out for another unit. This is an easy, economical way for job shops to get in-line precision part inspection, increasing shop capabilities, and opening new avenues of business.
The PG-Series gages bring reliable ID gaging to the manufacturing floor with no need for electrical or air connections, making them immune to fluctuations in line voltage or air pressure. A single PG gage can measure a wide range of part diameters, offering greater versatility at a lower cost than dedicated devices, such as air gages.
