(Wall Colmonoy Headquarters: Madison Heights, Michigan) -- Wall Colmonoy Aerobraze will be exhibiting at Booth 2703 at Aviation Week MRO Americas, April 26 through 28, 2022, in Dallas.
Aerobraze will be promoting its OEM and aftermarket products and services for the aerospace and aviation industry. Aerobraze specializes in manufacturing and repairing aerospace components, such as heat exchangers and oil coolers for commercial and military aircraft; Nicrocraft aircraft exhaust systems for general aviation, rotorcraft, and piston engines; and turbine vanes, nozzles, blades, honeycomb brazing, and engine compressor diffusers to make engines and parts last longer in service. Components are produced through the processes of vacuum brazing, heat treatment, welding, thermal spraying, and machining.
Franklin Bronze Precision Components, a subsidiary of Wall Colmonoy, will be joining the exhibit to promote its investment casting capabilities.
