(Titan Tool Supply: Buffalo, NY) -- Titan Tool Supply, a worldwide supplier of optical instrumentation and precision micro-finishing tools, introduces its L-Series of family of rigid, industrial-grade micro fiberscopes, also known as fiberoptic borescopes.
The L-Series is designed to perform accurate and reliable remote visual inspections and diagnostics in hard-to-reach, remote, or otherwise inaccessible areas—all without machinery and equipment disassembly or disruption. The series is offered in two unique models: the Model L-1, featuring a 1-mm diameter, 42° field of view, and a 6-in. working range; and the Model L-2, featuring a 2-mm diameter, 50° field of view, and a 12-in. working range. The overall focal length range is 0.118 in. to 0.236 in. (3 mm to 6 mm).
